Hello, recently I was trying to connect n8n with a API form Bling (it’s used to save data about store products, payment, shipment, etc). And Bling is now using it’s V3 version of it’s API, which requeries to use oauth2. I put all the credentials asked on n8n that I could find, client_id, client_secret and a authorization_URL that it seems to be working, but when I give authorization I received the following error: “Something went wrong, try again later!”
After reading Bling documentation, I saw that the example they use is for supported extensions on their stores, so my theory is that there is something wrong on the redirect_url from n8n.
Can anyone tell me if Bling is compatible or not with Bling? Or what I could be doing wrong?
Edit.: Okay, it’s possible this error screen is irrelevant, as all I need is a code from the url so I can get the access_token, which I did, the issue is. When I put the access code on the n8n header in a http request. It keeps saying I need a access code to log in, as if I didn’t one.
- I tried it this way and putting the Bearer where Authorization is.
- n8n version: 1.64.3
- Database (default: SQLite):
- **Running n8n vian: 8n cloud
- Operating system: Windows
