Connecting wave speed to workflow
I’m fairly green and can use some guidance to connect wave speed ( Generate video clips) to my work flow. I am currently getting [ Problem in node ‘Generate Video Clips (Wavespeed AI)‘
Bad request - please check your parameters]
I have input the api, but I’m thinking I have the wrong thing selected here. please advise
Hey @ggm hope all is good. Welcome to the community.
Have you checked your parameters? How do they look like?
I have the link to the product I would like to use , after that; I am unsure what do implement next
It is probably is going to be something about the HTTP Request body that you are sending.
where do I go to edit it, and what should I edit
There’s now a wavespeed node available in the community nodes. https://www.npmjs.com/package/n8n-nodes-wavespeed
