- n8n version:1.3.61
- Database: Postgres
- n8n EXECUTIONS_PROCESS setting: main
- Operating system: Linux VM
Kindly provide a solution ASAP
Hi @MounikaNangineni ,
Welcome to the community! ![]()
It looks like you’re using the wrong hostname/IP address. Could you try inserting you actual IP address instead of the localhost and see if the error persists?
Hi @mariana-na ,
By using actual IP address its taking as localhost still error persists.
Are you still getting the same error or a different one?
It seems that the altnames do not include your IP address. You might need to review your CA to make sure it includes your localhost.
