I am trying to get the AI node to use supabase as postgres chat memory. I have done a lot of searching, but the closest I got was some replies that said something about not working with ip v4. I don’t really understand but refuse to believe this can’t be resolved. I am trying to see the exact message N8N sends for it’s request so I can see if it is trying the same format that works from the CLI.
I tried many combinations of IP address and port from my cli, and finally hit upon
C:\Users\Owner\Documents\GitHub\AgentSwarm0125\examples>curl -H “apikey:<ANON_KEY from supabase>” “http://localhost:8000/rest/v1/messages”
which returned the contents of the table (my table is named messages).
I went on and tried similar combinations in postgres credentials. While every combo with port 5432 failed with a message, with port 8000 only local host failed with similar message.
{ “errno”: -111, “code”: “ECONNREFUSED”, “syscall”: “connect”, “address”: “192.168.65.254”, “port”: 5432 }
Three different addresses, docker network IP, docker container name and host.docker.internal all responded with “Connection terminated unexpectedly” Every time n8n returns “connection terminated” the docker log reports
2025-02-05 20:44:07 2025/02/06 04:44:07 [error] 1118#0: *585923 [kong] access.lua:53 [basic-auth] header has unrecognized format, client: 192.168.90.1, server: kong, request: “GET / HTTP/2.0”, host: “192.168.1.235:8443”
http://host.docker.internal:3000/rest/v1 connects and works with my supabase credential.
I set N8N to debug, and the logs show the request info, but still not the whole request string (so I can see the header format).
2025-02-07 12:27:56 Connection terminated unexpectedly
2025-02-07 12:27:56 Error: Connection terminated unexpectedly
2025-02-07 12:27:56 at /usr/local/lib/node_modules/n8n/node_modules/pg-pool/index.js:45:11
2025-02-07 12:27:56 at processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-02-07 12:27:56 at PostgresChatMessageHistory.ensureTable (/usr/local/lib/node_modules/n8n/node_modules/@langchain/community/dist/stores/message/postgres.cjs:97:13)
2025-02-07 12:27:56 at PostgresChatMessageHistory.getMessages (/usr/local/lib/node_modules/n8n/node_modules/@langchain/community/dist/stores/message/postgres.cjs:119:9)
2025-02-07 12:27:56 at BufferWindowMemory.loadMemoryVariables (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/memory/buffer_window_memory.cjs:85:26)
2025-02-07 12:27:56 at BufferWindowMemory.callMethodAsync (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/utils/logWrapper.js:16:16)
2025-02-07 12:27:56 at Proxy.connectionType (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/utils/logWrapper.js:55:43)
2025-02-07 12:27:56 at AgentExecutor._formatValues (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/chains/base.cjs:131:31)
2025-02-07 12:27:56 at AgentExecutor.invoke (/usr/local/lib/node_modules/n8n/node_modules/langchain/dist/chains/base.cjs:53:28)
2025-02-07 12:27:56 at ExecuteContext.toolsAgentExecute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/agents/Agent/agents/ToolsAgent/execute.js:185:30)
2025-02-07 12:27:56
2025-02-07 12:27:56 The session “7skwtwjnug” is not registered
There has got to be a combo for the postgres chat memory node and postgres credential that will work.
- **n8n version:1.72.1
- **Database (default: SQLite):supabase in docker
- **n8n EXECUTIONS_PROCESS setting (default: own, main):Must be default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):Docker
- **Operating system:Windows
