Connection lost, Origin header is missing, ResponseError: Invalid origin!
After I upgrade n8n 1.95.3 on server I got error.
Former version n8n 1.86.1 had no problem.
And I don`t have nginx server on AWS.
What is the error message?
  • Workflow screen : Connection lost
  • Server logs : Origin header is missing, ResponseError: Invalid origin!
  • n8n version: 1.95.3
  • Database: Postgresql
  • Running n8n via: Docker compose
  • Operating system: ubuntu on AWS EC2
Whole setting of docker-compose.yml
services:
  n8n:
    image: n8nio/n8n:1.95.3
    restart: always
    ports:
      - "5678:5678"
    environment:
      - N8N_HOST=test.com
      - GENERIC_TIMEZONE=Asia/Seoul
      - N8N_BASIC_AUTH_ACTIVE=true
      - N8N_BASIC_AUTH_USER=test
      - N8N_BASIC_AUTH_PASSWORD=test
      - N8N_SECURE_COOKIE=false
      - N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
      - DB_TYPE=postgresdb
      - DB_POSTGRESDB_HOST=test.com
      - DB_POSTGRESDB_PORT=5432
      - DB_POSTGRESDB_USER=test
      - DB_POSTGRESDB_PASSWORD=test
      - DB_POSTGRESDB_SSL_REJECT_UNAUTHORIZED=false
      - DB_POSTGRESDB_DATABASE=n8n_test
      - DB_POSTGRESDB_SCHEMA=n8n_test
      - N8N_LOG_LEVEL=debug
      - N8N_LOG_OUTPUT=console,file
      - DB_LOGGING_ENABLED=true
      - DB_LOGGING_OPTIONS=info
      - N8N_PUSH_BACKEND=sse
      - N8N_WORKFLOW_TAGS_DISABLED=false
      - EXECUTIONS_DATA_PRUNE=true
      - EXECUTIONS_DATA_MAX_AGE=720
      - EXECUTIONS_DATA_PRUNE_MAX_COUNT=200000
      - N8N_PUSH_BACKEND = sse
      - N8N_PROTOCOL = http
      - N8N_PROXY_HOPS = 1
      - N8N_EDITOR_BASE_URL=http://test.com
      - N8N_PORT=5678
      - WEBHOOK_URL=http://test.com
      - VUE_APP_URL_BASE_API=test.com
      - N8N_DISABLE_PRODUCTION_MAIN_PROCESS=true
      - N8N_RESTRICTED_MODE=true
      - N8N_ALLOWED_ORIGINS=http://test.com
      - N8N_DISABLE_UI_REALTIME=false
    volumes:
      - n8n_data_1.95.3:/home/node/.n8n
volumes:
  n8n_data_1.95.3:
    external: true
Error logs
n8n-1  | 2025-06-11T04:39:34.185Z | warn | Origin header is missing {"scopes":["push"],"file":"index.js","function":"handleRequest"}
n8n-1  | ResponseError: Invalid origin!
n8n-1  |     at Push.handleRequest (/usr/local/lib/node_modules/n8n/src/push/index.ts:143:10)
n8n-1  |     at /usr/local/lib/node_modules/n8n/src/push/index.ts:100:10
n8n-1  |     at Layer.handleRequest (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/router@2.2.0/node_modules/router/lib/layer.js:152:17)
n8n-1  |     at trimPrefix (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/router@2.2.0/node_modules/router/index.js:342:13)
n8n-1  |     at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/router@2.2.0/node_modules/router/index.js:297:9
n8n-1  |     at processParams (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/router@2.2.0/node_modules/router/index.js:582:12)
n8n-1  |     at next (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/router@2.2.0/node_modules/router/index.js:291:5)
n8n-1  |     at AuthService.authMiddleware (/usr/local/lib/node_modules/n8n/src/auth/auth.service.ts:85:17)
n8n-1  |     at processTicksAndRejections (node:internal/process/task_queues:95:5)
Hi,
I can confirm I have the same issue while running n8n within a private AWS EC2 instance behind Cloudfront.
No issue with 1.86.0, and error occurs with 1.87.0: Release n8n@1.87.0 · n8n-io/n8n · GitHub. It may be related to this huge refactor: fix(core): Add cross-origin checks on push endpoints by netroy · Pull Request #14365 · n8n-io/n8n · GitHub
