We are trying to set up Notion node for a workflow to access the Database in Notion. For that we were trying to set up the credentials using Notion api key.
I created an integration with read, write and edit access in Notion. Also connected to the database but No data is returned when the node was executed.
Our node has an option to get users as well so under the User Capabilities we would also need the Read user information without email addresses option. Our credential test also uses this endpoint to make sure we can connect as it will typically use less data than some of the other options.
I added the User permission also to the notion integration. Like given in the question is the integration is already added to notion page and that has the database.
Is there anyother steps to do, I’m still not getting any response after running the notion node.
Yes It was done already. I have attached it in the screenshot along with the question.
It is working now I’m able to collect info from database now. I think it took some time to reflct the changes in Notion and n8n Notion Node.
Thank you @Jon and @MutedJam
