Connection with slack to receive messages - Challenge -Error
Hi, I am trying to connect Slack to n8n, with a webhook.
When entering the webhook production url I get an error in the slack configuration, where I get this error: “Your request URL responded with an HTTP error. Update your URL to receive a new request and challenge value.”
I have the webhook to verify it correctly. I try with postman and it works fine.
I’m doing it in the cloud, because locally I thought it could be my mistake, but it still doesn’t work.
I saw this problem in similar threads, but i didn´t find a clear answer.
Thanks in advaice.
Hey @AlexOptimizalo,
We have a Slack trigger node now that would take care of this for you but looking at your request can you try removing the " from the $json.body.challenge and see if that changes anything.
Have you also checked the workflow execution log to see if it is working correctly?
I add search:read in user token scopes and now it works fine. The only problem that I have not solved is that I am not able to let me send direct messages to the application, I have these activated on write:
chat:write
chat:write.customize
im:write
mpim:write
usergroups:write
users:write
But well, I imagine this is already a Slack problem not n8n’s.
