Connectivity Issues with n8n Workflows
I’m having trouble accessing any workflow I’ve created. As soon as I access it, a notification appears in the top right corner saying: “Connection lost.”
I use n8n on an on-premise machine, running docker-compose.
My docker-compose.yml
Error screenshot
  • n8n version: Latest
  • Database (default: SQLite): MySQL 5.7
  • Operating system: Ubuntu
Hey @GuilhermeTrivilin,
My first thought is your reverse proxy is not correctly configured to handle websockets, Can you try accessing your n8n instance using the IP / bypassing the reverse proxy to see if the issue is still there?
When accessing directly via the machine’s IP, it works correctly. Additionally, when accessing both through the machine’s IP and my domain, the list of workflows returns different items. What could be the cause?
An important note is that we use Cloudflare, and it supports WebSocket by default.
Returning differnet workflows is odd it should be the same, It could be that the cloudflare caching is causing an issue. Are you using a Cloudflare tunnel or just Cloudflare for DNS?
@Jon , i’m using cloudflare for DNS only
@Jon, I believe it has to do with my nginx configuration. I don’t have much expertise in this regard, can you help me? Here’s my nginx config:
server {
    listen 80;
    server_name n8n-xxxx.kiskadi.com;
    location / {
        return 301 https://$host$request_uri;
server {
    listen 443 ssl;
    ssl_certificate /etc/letsencrypt/live/n8n-xxxx.kiskadi.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/n8n-xxxx.kiskadi.com/privkey.pem;
    include /etc/letsencrypt/options-ssl-nginx.conf;
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
    location / {
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
nginx would be the reverse proxy I asked about previously, So it looks like you don’t have the options set that nginx needs for websockets to function properly. Try something like the below, I would run it past your server admin first to verify but it should be close to what you need.
server {
    listen 80;
    location / {
server {
    listen 443 ssl;
    location / {
        proxy_set_header Connection 'Upgrade';
        proxy_http_version 1.1;
Thank you so much for the help, @Jon! The configuration you sent me didn’t work, but I disabled some buffering and cache, and it worked (I found this information in another post here in the community).
For anyone facing the same issue, in the end, my nginx looked like this:
server {
    listen 80;
    location / {
server {
    listen 443 ssl;
    location / {
        # To make the websocket work, add the following lines to your nginx:
        proxy_buffering off;
        proxy_cache off;
        chunked_transfer_encoding off;
