Hello,
I thank that continue on fail is not supported by ERPNext node,
Can anybody confirm please?
Thank you very much
Hello,
Thank you very much
Confirmed. It’s really easy to add, though.
Thank you for your reply.
Can you please let me know how can I do it?
Thanks
You add and try/catch in the loop. You can literally copy the code from any other node that supports it.
