I have created the following workflow section. How can i make sure the first line of nodes finished even if the second one fails? In this case it basically separates if a create or update operation needs to be executed.
- n8n version:0.225.1
- Database (default: SQLite):postgres
- Running n8n via (Docker, npm, n8n cloud, desktop app):cloudron
In the node settings for your http request you can ignore errors. Otherwise if you need to see failed workflows, a hacky way is to just put a couple of No Operation nodes before your troublesome http request to ensure it runs last
Thank you very much
Is there no better way than turning off error handling or a relatively ugly workaround? I though maybe there is a magical combination of using merges. But that was my hope speaking
You can also use the Merge node to run your second branch after the first one like so:
This uses the Choose Branch → Wait for Both Inputs to Arrive setting of the Merge node:
@MutedJam Thank you very much. The idea i great but since there is an if to separate routes one will very likely never be entered leading to the following state:
The final node is never reached due to the waiting for input 1
