Couldn’t connect with these settings connect ECONNREFUSED 127.0.0.1:3306
Retry
Hey @Elys_Razafindrakoto,
Welcome to the community :cake:
You have not included any details that we can use to help you, However as a starting point I will assume you are running n8n in a docker container and trying to connect to your database.
Using 127.0.0.1 won’t work as it is local to the machine you are running so you would instead need to use the the IP of the database server or if using the default docker networks you can use 172.17.0.1 as the IP and see if that works.
