Couldn’t connect with these settings ETIMEDOUT
I have tried installing and reinstalling 3 times. But I still don’t understand why I still get the error below.
I can’t set up a telegram account.
Retrying
ETIMEDOUT
0|n8n      | User settings loaded from: /home/sysadmin/.n8n/config
0|n8n      | 2024-04-23T11:20:08.170Z | info     | Initializing n8n process "{ file: 'start.js', function: 'init' }"
0|n8n      | n8n ready on 0.0.0.0, port 5678
0|n8n      | Version: 1.37.3
0|n8n      |
0|n8n      | Editor is now accessible via:
0|n8n      | https://n8n.*******.net:5678/
0|n8n  | 2024-04-23T11:20:23.115Z | verbose  | Execution for workflow My workflow was assigned id 8 "{\n  executionId: '8',\n  file: 'WorkflowRunner.js',\n  function: 'runMainProcess'\n}"
0|n8n  | 2024-04-23T11:20:23.124Z | verbose  | Workflow execution started "{\n  workflowId: '7rWgGqKdMoVye9bM',\n  file: 'LoggerProxy.js',\n  function: 'exports.verbose'\n}"
0|n8n  | 2024-04-23T11:20:23.130Z | verbose  | Started execution of workflow "My workflow" from webhook with execution ID 8 "{\n  executionId: '8',\n  file: 'WebhookHelpers.js',\n  function: 'executeWebhook'\n}"
0|n8n  | 2024-04-23T11:20:23.523Z | verbose  | Workflow execution finished with error "{\n  error: {\n    level: 'warning',\n    tags: {},\n    extra: undefined,\n    context: {},\n    functionality: 'regular',\n    name: 'NodeApiError',\n    timestamp: 1713871223521,\n    node: {\n      parameters: [Object],\n      id: '0b07abb2-42f0-4811-9ee7-6624feb0aba5',\n      name: 'Telegram',\n      type: 'n8n-nodes-base.telegram',\n      typeVersion: 1.1,\n      position: [Array],\n      credentials: [Object]\n    },\n    messages: [\n      'connect ETIMEDOUT 149.154.167.220:443 | connect ENETUNREACH 2001:67c:4e8:f004::9:443 - Local (:::0)'\n    ],\n    httpCode: 'ETIMEDOUT',\n    description: undefined,\n    message: \"The connection timed out, consider setting 'Retry on Fail' option in the node settings\",\n    stack: \"NodeApiError: The connection timed out, consider setting 'Retry on Fail' option in the node settings\\n\" +\n      '    at Object.apiRequest (/usr/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Telegram/GenericFunctions.ts:218:9)\\n' +\n      '    at processTicksAndRejections (node:internal/process/task_queues:95:5)\\n' +\n      '    at Object.execute (/usr/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/Telegram/Telegram.node.ts:2053:21)\\n' +\n      '    at Workflow.runNode (/usr/lib/node_modules/n8n/node_modules/n8n-workflow/src/Workflow.ts:1378:8)\\n' +\n      '    at /usr/lib/node_modules/n8n/node_modules/n8n-core/src/WorkflowExecute.ts:1050:29\\n' +\n      '    at /usr/lib/node_modules/n8n/node_modules/n8n-core/src/WorkflowExecute.ts:1726:11'\n  },\n  workflowId: '7rWgGqKdMoVye9bM',\n  file: 'LoggerProxy.js',\n  function: 'exports.verbose'\n}"
  • n8n version: 1.37.3
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Default
  • Operating system: Ubuntu 22.04 LTS
Hello @tohuenet
The ENETUNREACH usually means that the n8n doesn’t have access to the internet. Maybe there are some firewall rules blocking access or interface issue (ipv6?)
Thank you for the reply. That’s problem of ipv6.
I have disabled ipv6 of Ubuntu then it works.
