Couldn’t connect with these settings
Guys, I need some help. I have a custom node that the connection test always displays “Couldn’t connect with these settings”. I analyzed the example of Postgres, FTP, Redis and other nodes, but none of them worked.
credentials: [
				required: true,
				testedBy: 'oracleConnectionTest',
When enabling the testedBy parameter, the message “Couldn’t connect with these settings” starts to be displayed on the connection screen. I can connect normally to Oracle but I believe that the connection test function is not being called as it does not display logs or feedback.
I tried this way, like the Postgres V2 example
I tried this way, like the Postgres V1 example
I tried several ways, none of them can call the connection test function.
An interesting test I did was to configure the test command in the OracleSqlApi.credentials.ts file: ICredentialTestRequest
With this command, the error logs are displayed in the vscode console.
I’m new to developing nodes for n8n, and I couldn’t understand why the connection test doesn’t work on my node even though I followed the examples of other nodes exactly. If anyone has any tips, any help would be appreciated. Thank you very much in advance.
  • n8n version: 1.21.0
  • Database: Postgres
  • Running n8n via: NPM in VSCode
  • Operating system: Windown
it says that the credentials testing function does not exist even though it exists, I followed several examples from other nodes but mine does not work. where am I going wrong?
Hi @leomangueira, I am sorry you’re having trouble. Perhaps you can share your repo for a closer look and one of our node builders (@marcus or @Jon) can have a closer look?
This is on my list still to look into, I think we have a GH issue open for it as well so it does look like this this is a bug that needs to be fixed rather than something in the node like I originally thought.
The dev ticket for this is PAY-1274.
