Can you share your ID? That will let me check what has happened, normally the message won’t get sent if the id is not valid or if the doesn’t match what we expect.
I checked the logs and I can see the message you sent come in, It looked a bit odd though so I checked your workflow again and on the Discord node you have not set the content to use an expression which is causing your issue.
or should I drag and drop something from the variable selector column? I tried the ones under headerParameters but none of them gives me my ID value…
thanks a lot
