Course Level 1 NodeOperationError at Discord node
I am working on the Course Level 1 and when I do the test step for the Discord node in Nathan’s Workflow I receive an error.
NodeOperationError: at Object.parseDiscordError (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/helpers/utils.js:74:12) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/actions/webhook/sendLegacy.operation.js:125:51) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Object.router (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/actions/router.js:69:26) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Discord/v2/DiscordV2.node.js:19:16) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:673:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1104:20
  "meta": {
    "instanceId": "a1990ee091ebdb88a61c9bb330b690c3b980668dbeffb5a5a6f43d1962165d13"
  "nodes": [],
  "connections": {},
  "pinData": {}
I expect this in Discord, saved from a previous test run:
n8n course APP 08/23/2024 4:31 PM
This week we’ve 16 booked orders with a total value of 2251.14. My Unique ID: 4a786295499412067c593044fcadae84
  • ** 1.56.2 (Cloud)**
  • default: SQLite:
  • n8n cloud
  • MacOS Sonoma 14.6.1
Solved.
The unique ID was entered incorrectly.
