Working through the Level-1 training and am blocked at the stage where my Workflow updates my progress into the Discord Channel “course-level-1”.
No Error message, workflow runs just fine.
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
“nodes”: [
“parameters”: {},
“name”: “Start”,
“type”: “n8n-nodes-base.start”,
“typeVersion”: 1,
“position”: [
-780,
300
“parameters”: {
“genericAuthType”: “httpHeaderAuth”,
“url”: “https://internal.users.n8n.cloud/webhook/custom-erp”,
“options”: {
“splitIntoItems”: true
“headerParametersUi”: {
“parameter”: [
“name”: “unique_id”,
“value”: “recY9TXVKNCpebKRi”
“name”: “HTTP Request”,
“typeVersion”: 2,
“position”: [
-580,
300
“credentials”: {
“httpHeaderAuth”: {
“id”: “4”,
“name”: “Header Auth account”
“parameters”: {
“operation”: “append”,
“application”: “app8cTsfXoYIyflzM”,
“table”: “processingOrders”,
“options”: {}
“name”: “Airtable”,
“type”: “n8n-nodes-base.airtable”,
“typeVersion”: 1,
“position”: [
120,
100
“credentials”: {
“airtableApi”: {
“id”: “6”,
“name”: “Airtable account”
“parameters”: {
“conditions”: {
“string”: [
“value1”: “={{$json[“orderStatus”]}}”,
“value2”: “processing”
“name”: “IF”,
“type”: “n8n-nodes-base.if”,
“typeVersion”: 1,
“position”: [
-400,
300
“parameters”: {
“keepOnlySet”: true,
“values”: {
“number”: [
“name”: “orderID”,
“value”: “={{$json[“orderID”]}}”
“string”: [
“name”: “employeeName”,
“value”: “={{$json[“employeeName”]}}”
“options”: {}
“name”: “Set”,
“type”: “n8n-nodes-base.set”,
“typeVersion”: 1,
“position”: [
-160,
100
“parameters”: {
“functionCode”: “// Code here will run only once, no matter how many input items there are.\n// More info and help: https://docs.n8n.io/nodes/n8n-nodes-base.function\n// Tip: You can use luxon for dates and $jmespath for querying JSON structures\n\nlet totalBooked = items.length;\nlet bookedSum = 0;\n\nfor(let i=0; i < items.length; i++) {\n bookedSum = bookedSum + items[i].json.orderPrice;\n}\nreturn [{json:{totalBooked, bookedSum}}];”
“name”: “Function”,
“type”: “n8n-nodes-base.function”,
“typeVersion”: 1,
“position”: [
-180,
340
“parameters”: {
“webhookUri”: “n8n Course Redirect”,
“text”: “=This week we have {{$json[“totalBooked”]}} booked orders with a total value of {{$json[“bookedSum”]}}. My Unique ID:{{$node[“HTTP Request”].parameter[“headerParametersUi”][“parameter”][0][“value”]}}”,
“options”: {}
“name”: “Discord”,
“type”: “n8n-nodes-base.discord”,
“typeVersion”: 1,
“position”: [
40,
340
“parameters”: {
“triggerTimes”: {
“item”: [
“mode”: “everyWeek”,
“hour”: 9
“name”: “Cron”,
“type”: “n8n-nodes-base.cron”,
“typeVersion”: 1,
“position”: [
260,
340
“connections”: {
“Start”: {
“main”: [
“node”: “HTTP Request”,
“type”: “main”,
“index”: 0
“HTTP Request”: {
“main”: [
“node”: “IF”,
“type”: “main”,
“index”: 0
“IF”: {
“main”: [
“node”: “Set”,
“type”: “main”,
“index”: 0
“node”: “Function”,
“type”: “main”,
“index”: 0
“Set”: {
“main”: [
“node”: “Airtable”,
“type”: “main”,
“index”: 0
“Function”: {
“main”: [
“node”: “Discord”,
“type”: “main”,
“index”: 0
This week we have 16 booked orders with a total value of 2251.14. My Unique ID: recY9TXVKNCpebKRi
n8n version:
Database you’re using (default: SQLite):
Running n8n with the execution process [own(default), main]:
Running n8n via [desktop app]:
