I want to create a chatbot using n8n’s frontend code only. I don’t want to set up the work-flow. If this is possible then how can do that? I just want to extract and install the front-end code and then change it to create chat-bot.
Hi @Mitul_Kheni, welcome to the community.
I am not fully sure I understand what you’re trying to do I am afraid. n8n’s code is public though, if you want to tinker with it: GitHub - n8n-io/n8n: Free and source-available fair-code licensed workflow automation tool. Easily automate tasks across different services. (the frontend portion lives under packages/editor-ui).
