I used schedule trigger, because zoho token will expiry every one hour so in one of the post MuteJam advised to run the scheduled trigger every 30 min.
This is error i am getting, i am not knowing how to pass the JSON body with data
That looks like Zoho is not happy with the data you are sending, It might be worth sending the request to something like webhook.site so you can inspect the data and check that it matches what the API is expecting.
If you go to webhook.site it gives you a url, You can then paste this into the http request node as the url and check the site this will then show you what you are sending.
I have scheduled one workflow, as per the output the token should change every time it gets executed, Can you please help me here what is the wrong in this workflow
Ok sure, I am got getting error
But when the workflow or node is executed, it should generate a new access token so that i can pass it to another HTTP request node which is Invoice Create Http node
Currently i am not able to see the new access token which was suppose to generate after every scheduled execution
Have you followed the documentation for OAuth with zoho? I would have expected the parameters to be in the body not the query. It also looks like you don’t have a url query option for access_type=offline
ERROR: Header name must be a valid HTTP token - currently i am trying to pass manually the auth token. But unable to know how to pass the access token.
I tried also Bearer $token - but it did not work
That looks like your authentication is still not correct, have you verified that what you are doing in n8n is the same as what you are doing in Postman? It looks like you are getting the response back from Zoho so this will be an authentication issue.
Why are you using header auth as an option? Does the OAuth2 credential not cover what you need for this?
N8N zoho Oauth2 are linked to zoho CRM, but most of the customers will not use CRM, customers will be having individual Zoho modules. So trying to connect with Zoho invoice module
