I’m trying to create a new Asana project from a template after the trigger on Pipedrive (Deal set to WON) gets activated. This doesn’t work as intended. I’ve been trying out multiple ways using JSON for Header and Body.
requested_dates: [0]: value: Day cannot be null
My workflow
“errorMessage”: “Bad request - please check your parameters”,
“errorDescription”: “requested_dates: [0]: value: Day cannot be null”,
“errorDetails”: {
“rawErrorMessage”: [
“400 - "{\"errors\":[{\"message\":\"requested_dates: [0]: value: Day cannot be null\",\"help\":\"For more information on API status codes and how to handle them, read the docs on errors: https://developers.asana.com/docs/errors\\\“}]}\””
“httpCode”: “400”
“n8nDetails”: {
“nodeName”: “HTTP Request”,
“nodeType”: “n8n-nodes-base.httpRequest”,
“nodeVersion”: 4.2,
“itemIndex”: 0,
“time”: “22.7.2025, 10:54:13”,
“n8nVersion”: “1.102.4 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“NodeApiError: Bad request - please check your parameters”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_1af219c3f47f2a1223ec4ccec249a974/node_modules/n8n-nodes-base/nodes/HttpRequest/V3/HttpRequestV3.node.ts:780:15)“,
" at processTicksAndRejections (node:internal/process/task_queues:105:5)”,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@[email protected][email protected][email protected]_/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1212:9)“,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@[email protected][email protected][email protected]_/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1582:27”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@[email protected][email protected][email protected]_/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2153:11"
- n8n version: 1.102.4
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): Kubernetes (Docker)
- Operating system: Linux
