Creating a task in YouGile via HTTP Request – JSON body not being parsed correctly
Hi everyone,
I’m trying to create a sticker (task) in YouGile using the HTTP Request node in n8n, but I keep getting errors related to the JSON body (either “invalid JSON” or the variables are sent literally as strings like “{{ $json.title }}”).
My setup:
  • Telegram Trigger → OpenAI (to analyze the message and return JSON with title, description, board_id, due_date, user_ids)
  • HTTP Request node to POST to YouGile API v2
Headers:
  • Authorization: Bearer [my-token]
  • Content-Type: application/json
I’m using “JSON/RAW Parameters” and “Body Content Type = JSON”.
I’ve tried several variants for the body, but none seem to produce a valid resolved JSON object:
  1. Separate fields in bodyParametersJson (each with ={{ }})
  2. Single expression in bodyParametersJson like ={{ { “title”: “{{ $json.title }}”, … } }}
In the “Resolved Expression Value” preview I either see unresolved variables, strings instead of arrays, or syntax errors.
Can someone please show me the exact correct way to write the body so that:
  • title and description are strings
  • dueDate is string or null
  • users is a real array of strings (not a stringified array)
I don’t want to specify columnId – the task should go to the default/first column of the board.
Any working example of a YouGile “create sticker” HTTP Request node would be greatly appreciated!
Thanks in advance!
Hi @sadchill, please can you provide your workflow in a code block for us to have a look at. If you can also pin some sample data from your Telegram node it will help a lot.
Hi, thanks for your response.
I’ve attached two codes for review:
  1. The full n8n workflow (API keys are hidden)
  2. Sample output data from the Telegram node
The workflow executes, but I’m facing an authorization issue when making requests to the Yougile API.
I consistently receive a 401 Unauthorized error, even though the API key is set in the request headers.
I suspect there may be an issue with how the Authorization header is formatted or with the request URL, but I haven’t been able to resolve it.
Any help or guidance would be greatly appreciated.
Thanks in advance.
N8N WORKFLOW
“name”: “Tennis School Task Management Assistant with Yougile Integration”,
“nodes”: [
“parameters”: {
“updates”: [
“message”
“additionalFields”: {}
“id”: “16c137fc-0eb8-416a-be1e-8bdf9d44c3fc”,
“name”: “Telegram Trigger”,
“type”: “n8n-nodes-base.telegramTrigger”,
“typeVersion”: 1.2,
“position”: [
8256,
736
“webhookId”: “6124341a-f511-40bc-9184-98e5debbe6a2”,
“credentials”: {
“telegramApi”: {
“id”: “Z7tOLdkSBMrwGgJJ”,
“name”: “Telegram account”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “id-1”,
“name”: “yougileApiUrl”,
“value”: “https://ru.yougile.com/api-v2”,
“type”: “string”
“id”: “id-2”,
“name”: “yougileApiKey”,
“value”: “Bearer Z72NZoT87QOTr5BXbDiP8XZqLkXktIUxTzjNh8wHYnvJMGynXZyZQREJ2SZ6tJm9”,
“type”: “string”
“id”: “id-3”,
“name”: “departments”,
“value”: “{ “Развитие”: “96acda1c-21eb-4dad-926e-81a0046e6825”, “Маркетинг”: “3cca2e43-9502-4a09-a0b0-2fefcdbf5fc2”, “Финансы”: “5e19d8b7-1d05-415f-b049-ee7cf30ad88d”, “Мероприятия и турниры”: “9117018c-ce0c-41ea-8ff8-3d54d3b7309b”, “Test”: “6f0ce0f1-e907-47b6-affe-96a00bd48a59”, “Работа на локации Рублево”: “5d366900-0e92-4f23-a647-cc4b5a2bb781” }”,
“type”: “object”
“includeOtherFields”: true,
“options”: {}
“id”: “4d524947-b00d-4d4e-a967-632b2475b5fb”,
“name”: “Workflow Configuration”,
“type”: “n8n-nodes-base.set”,
“typeVersion”: 3.4,
“position”: [
8480,
736
“alwaysOutputData”: false
“parameters”: {
“promptType”: “define”,
“text”: “={{ $json.message.text }}”,
“hasOutputParser”: true,
“options”: {
“systemMessage”: “Ты — внутренний интеллектуальный ассистент школы тенниса 10is, работающий внутри автоматизированной системы управления задачами.\n\nТвоя цель — превратить любое сообщение от сотрудника (текст или расшифрованное голосовое сообщение) в корректно структурированную задачу для Yougile.\n\nОтделы (проекты в Yougile):\n1. Маркетинг - реклама, контент, соцсети, идеи для продвижения, рекламные кампании\n2. Развитие - улучшение процессов, автоматизация, внедрение новых инструментов, стратегические задачи, внутренние проекты\n3. Мероприятие и турниры - организация турниров, ивенты, расписание мероприятий, координация участников, партнёры\n4. Финансы - оплаты, счета, акты, зарплаты, финансовая отчётность\n5. Работа на Локации Рублево - работа тренеров, расписание занятий, замены, вопросы клиентов на локации, инвентарь и состояние площадок\n6. Test - тестовые задачи, отладка автоматизации\n\nЛогика классификации:\n- Если запрос связан с рекламой или контентом → Маркетинг\n- Если запрос про улучшение, внедрение, развитие → Развитие\n- Если запрос про события, турниры, мероприятия → Мероприятие и турниры\n- Если запрос про деньги → Финансы\n- Если запрос связан с ежедневной работой локации Рублево → Работа на Локации Рублево\n- Если запрос не удалось уверенно классифицировать → Test\n\nФормирование задачи:\n1. Заголовок (title): короткий, деловой, без воды\n2. Описание (description): суть задачи, контекст, ожидаемый результат, пошаговый план выполнения\n3. Дедлайн (deadline): если не указан срок:\n - срочная операционная задача → +1–2 дня\n - обычная рабочая задача → +3–5 дней\n - стратегическая → +7–14 дней\n Формат даты: YYYY-MM-DD\nДедлайн ты должен считать от сегодняшний даты,27 декабря 2025 года\n4. Отдел (department): название отдела из списка выше\n\nЕсли сообщение пришло из голосового ввода, игнорируй слова-паразиты и разговорную речь.\nВерни структурированный JSON с полями: title, description, deadline, department.”
“id”: “b5637713-3022-40dc-b3dc-c6a0ac4ff20c”,
“name”: “Task Classification Agent”,
“type”: “@n8n/n8n-nodes-langchain.agent”,
“typeVersion”: 3.1,
“position”: [
8800,
752
“parameters”: {
“model”: {
“__rl”: true,
“mode”: “list”,
“value”: “gpt-4.1-mini”
“builtInTools”: {},
“options”: {}
“id”: “b3a26822-e065-44da-9460-781ad2e879e7”,
“name”: “OpenAI Chat Model”,
“type”: “@n8n/n8n-nodes-langchain.lmChatOpenAi”,
“typeVersion”: 1.3,
“position”: [
8704,
960
“credentials”: {
“openAiApi”: {
“id”: “WB9CaWTjeXoJ4VtI”,
“name”: “n8n free OpenAI API credits”
“parameters”: {
“sessionIdType”: “customKey”,
“sessionKey”: “={{ $json.message.chat.id }}”
“id”: “7602c3f0-9243-436b-99ae-bdcddcaddb6b”,
“name”: “Simple Memory”,
“type”: “@n8n/n8n-nodes-langchain.memoryBufferWindow”,
“typeVersion”: 1.3,
“position”: [
8832,
960
“parameters”: {
“schemaType”: “manual”,
“inputSchema”: “{\n\t"type": “object”,\n\t"properties": {\n\t\t"title": {\n\t\t\t"type": “string”,\n\t\t\t"description": “The title of the task”\n\t\t},\n\t\t"description": {\n\t\t\t"type": “string”,\n\t\t\t"description": “The description of the task”\n\t\t},\n\t\t"deadline": {\n\t\t\t"type": “string”,\n\t\t\t"description": “The deadline in YYYY-MM-DD format”,\n\t\t\t"pattern": “^\\d{4}-\\d{2}-\\d{2}$”\n\t\t},\n\t\t"department": {\n\t\t\t"type": “string”,\n\t\t\t"description": “The department for the task”\n\t\t}\n\t},\n\t"required": [“title”, “description”, “deadline”, “department”]\n}”
“id”: “b771da10-3e94-4dc2-a0d7-b8494711836f”,
“name”: “Structured Output Parser”,
“type”: “@n8n/n8n-nodes-langchain.outputParserStructured”,
“typeVersion”: 1.3,
“position”: [
8960,
960
“parameters”: {
“chatId”: “={{ $(‘Telegram Trigger’).first().json.message.chat.id }}”,
“text”: “=✅ Задача создана!\n\nОтдел: {{ $(‘Task Classification Agent’).first().json.output.department }}\nЗаголовок: {{ $(‘Task Classification Agent’).first().json.output.title }}\nДедлайн: {{ $(‘Task Classification Agent’).first().json.output.deadline }}”,
“id”: “6812e41e-9769-4798-ad2d-0c411d428ade”,
“name”: “Send Telegram Response”,
“type”: “n8n-nodes-base.telegram”,
“typeVersion”: 1.2,
“position”: [
9808,
736
“webhookId”: “14f94324-2b65-4b65-ab10-39b6fb4853aa”,
“credentials”: {
“telegramApi”: {
“parameters”: {
“method”: “POST”,
“url”: “https://yougile.com/api-v2/tasks”,
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: “Authorization”,
“value”: “Bearer vXDcoCinmAAWgWgf01DrixDTpuQBBRuAb-UgI1FqKLDkAiSeqgEpshc13tm3EqM6”
“sendBody”: true,
“specifyBody”: “json”,
“jsonBody”: “{\n “title”: “test task”,\n “columnId”: “fefbc00f-3870-4f52-807f-225ce2e4c701”,\n “description”: “string”,\n “archived”: false,\n “completed”: false,\n “subtasks”: [\n “0fe1e417-2415-4e76-932a-ca07a25d6c64”,\n “f0118d9e-2888-48e4-a172-116085da4279”\n ],\n “assigned”: [\n “80eed1bd-eda3-4991-ac17-09d28566749d”\n ],\n “deadline”: {\n “deadline”: 1653029146646,\n “startDate”: 1653028146646,\n “withTime”: true,\n “history”: [\n “string”\n ],\n “blockedPoints”: [\n “string”\n ],\n “links”: [\n “string”\n ]\n },\n “timeTracking”: {\n “plan”: 10,\n “work”: 5\n },\n “checklists”: [\n {\n “title”: “list 1”,\n “items”: [\n {\n “title”: “option 1”,\n “isCompleted”: false\n },\n {\n “title”: “option 2”,\n “isCompleted”: false\n }\n ]\n }\n ],\n “stickers”: {\n “fbc30a9b-42d0-4cf7-80c0-31fb048346f9”: “0baced9640b2”,\n “645250ca-1ae8-4514-914d-c070351dd905”: “815016901edd”,\n “660b9096-a2d0-45df-b09a-b53ba521e86f”: “empty”,\n “060f5185-e613-4f74-97c1-060667cc3a7e”: “ООО «Производство»”,\n “46d005ea-c89e-449b-878e-d3cc43204a5a”: “345.123”\n },\n “color”: “task-red”,\n “idTaskCommon”: “ID-484”,\n “idTaskProject”: “DEV-484”,\n “stopwatch”: {\n “running”: true\n },\n “timer”: {\n “running”: true,\n “seconds”: 600\n },\n “deal”: {\n “dealAmount”: 25000000,\n “contactPersonIds”: [\n “string”\n ],\n “organizationId”: “string”,\n “customFields”: {}\n }\n}”,
“options”: {}
“typeVersion”: 4.3,
“position”: [
9408,
736
“id”: “234c412e-7ac8-4303-a39f-645a7a3d85cc”,
“name”: “HTTP Request1”
“pinData”: {},
“connections”: {
“Telegram Trigger”: {
“main”: [
“node”: “Workflow Configuration”,
“type”: “main”,
“index”: 0
“Workflow Configuration”: {
“main”: [
“node”: “Task Classification Agent”,
“type”: “main”,
“index”: 0
“OpenAI Chat Model”: {
“ai_languageModel”: [
“type”: “ai_languageModel”,
“index”: 0
“Simple Memory”: {
“ai_memory”: [
“type”: “ai_memory”,
“index”: 0
“Structured Output Parser”: {
“ai_outputParser”: [
“type”: “ai_outputParser”,
“index”: 0
“Task Classification Agent”: {
“main”: [
“node”: “HTTP Request1”,
“type”: “main”,
“index”: 0
“HTTP Request1”: {
“main”: [
“node”: “Send Telegram Response”,
“type”: “main”,
“index”: 0
“active”: false,
“settings”: {
“executionOrder”: “v1”,
“availableInMCP”: false
“versionId”: “251cb3e8-4f2f-451f-91f8-89307280570a”,
“meta”: {
“instanceId”: “55bd4614c9bd5c50ae48a380b8ba2bb2e962cb99838b7af0d22bb66da9c42a94”
“id”: “rgvuldIICy6eeHFU”,
“tags”:
Telegram Node
“name”: “Telegram NODE”,
“nodes”: [
“parameters”: {
“updates”: [
“message”
“id”: “70204b24-3887-49d7-9ffd-3097d3b15b48”,
“typeVersion”: 1.2,
“position”: [
0,
0
“credentials”: {
“telegramApi”: {
“pinData”: {},
“connections”: {},
“active”: false,
“settings”: {
“versionId”: “b06d6f16-c021-4e18-849a-2515d6249f51”,
“meta”: {
“id”: “MuDKVeZbUsNPED6P”,
“tags”:
Hi @sadchill please put the json inside of a code block, else we cant use the above as the site changes the formatting and breaks the workflow
“nodes”: [
“parameters”: {
“updates”: [
“message”
“typeVersion”: 1.2,
“position”: [
8256,
736
“credentials”: {
“telegramApi”: {
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “id-1”,
“type”: “string”
“id”: “id-2”,
“type”: “string”
“id”: “id-3”,
“type”: “object”
“options”: {}
“typeVersion”: 3.4,
“position”: [
8480,
736
“parameters”: {
“options”: {
“typeVersion”: 3.1,
“position”: [
8800,
752
“parameters”: {
“model”: {
“__rl”: true,
“mode”: “list”,
“builtInTools”: {},
“options”: {}
“typeVersion”: 1.3,
“position”: [
8704,
960
“credentials”: {
“openAiApi”: {
“parameters”: {
“typeVersion”: 1.3,
“position”: [
8832,
960
“parameters”: {
“typeVersion”: 1.3,
“position”: [
8960,
960
“parameters”: {
“typeVersion”: 1.2,
“position”: [
9808,
736
“credentials”: {
“telegramApi”: {
“parameters”: {
“method”: “POST”,
“parameters”: [
“sendBody”: true,
“options”: {}
“typeVersion”: 4.3,
“position”: [
9408,
736
“pinData”: {},
“connections”: {
“main”: [
“type”: “main”,
“index”: 0
“main”: [
“type”: “main”,
“index”: 0
“index”: 0
“Simple Memory”: {
“ai_memory”: [
“index”: 0
“index”: 0
“main”: [
“type”: “main”,
“index”: 0
“HTTP Request1”: {
“main”: [
“type”: “main”,
“index”: 0
“active”: false,
“settings”: {
“meta”: {
“tags”:
Thanks for sharing the workflow, however Im a bit confused with what the issue is?
In your original question you stated that the HTTP node was complaining about the json body, however in the example you provided there is no variable expressions to reference data from the AI Agent. The JSON seems to be fine at a glance.
Further down you’re stating that the issue now is a 401 Auth issue?
PS, please note that you have leaked your API keys in the shared workflow and I would advise you to go invalidate those keys as soon as possible.
To help look into this issue further, please can you let us know what the issue is you’re experiencing and sharing a working workflow with pinned data for the Telegram trigger. This will help me run the workflow on my instance to try and trace the issue.
I received a response from support of youGile that the interface between them is currently not working or are you developing a tether here?
