How I create a JSON with subparameter using graphics interface of N8N? example:
Inside “contact” I have “email”, like this:
What information I must to write to fill the “email” value? I need to generate the JSON above.
Welcome to the community @adriano.ferreira
The HTTP node does not support dot notation in the body. To achieve that, you need to set an expression in the value. Example: {{ { "email": "[email protected]" } }}
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"requestMethod": "POST",
"options": {},
"bodyParametersUi": {
"parameter": [
"name": "tenant_id",
"value": "1"
"name": "login",
"value": "test"
"name": "contact",
"value": "={{ { \"email\": \"[email protected]\" } }}"
"name": "HTTP Request",
"typeVersion": 1,
"position": [
580,
320
"connections": {
"Start": {
"main": [
"node": "HTTP Request",
"type": "main",
"index": 0
For anyone look at this later, dot notation for HTTP node is now supported from version 0.223.0
fix(HTTP Request Node): Support for dot notation in JSON body by michael-radency · Pull Request #5867 · n8n-io/n8n (github.com)
I’ve tested it and it works great. So to answer the original question, using contact.email
as the name should work.
It can also go multiple layers deep. I was able to use data.attributes.note_category_id
for an HTTP POST request.
