How to create variable product in woocommerce?
there is no any variation in Woocommerce triggers or actions
the only thing related to variation is Parent ID which links a variation to parent product
- n8n version:
- Database (default: SQLite):
- Operating system:
The built in special-purpose nodes like WooCommerce implement most of the common/core features, but typically do not cover everything. The same is true for nodes like Spotify, or Jira for instance.
What you can often do instead, is use the credentials mechanism from the special-purpose node (e.g. the WooCommerce account one created from a WooCommerce node) with a normal HTTP request node, and construct the call to the product/service API directly.
I think in your case, you’ll want to review the WooCommerce docs
