I try to insert data from RabbitMQ trigger to Postgres.
When I manual execute workflow it’s work but when I Iactive workflow it show error.
I copy output data form RabbitMQ trigger in error execute and run it on manual , it’s work.
ERROR: Credentials could not be decrypted. The likely reason is that a different “encryptionKey” was used to encrypt the data.
Error: Credentials could not be decrypted. The likely reason is that a different "encryptionKey" was used to encrypt the data.
at Credentials.getData (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/Credentials.js:41:19)
at CredentialsHelper.getDecrypted (/usr/local/lib/node_modules/n8n/dist/CredentialsHelper.js:191:51)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at getCredentials (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/NodeExecuteFunctions.js:1260:33)
at Object.router (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Postgres/v2/actions/router.js:36:25)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:658:19)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:631:53
n8n version : 1.9.3
execute by queue mode
deploy on docker
