[CRITICAL ISSUE] Webflow nodes using v1 API stopped working
As of this morning, all the Webflow nodes which were built using v1 API are throwing errors. The automations aren’t working anymore. Nothing was changed.
  • There was a problem loading the parameter options from server: “fields is not iterable”
N/A
  • n8n version: 1.55.3
  • Running n8n via: n8n cloud
Hey @shreyansh-perpetual,
Welcome to the community :partying_face:
Webflow are planning to remove the v1 API support which we don’t have any control over so you will need to update your workflows at some point.
My understanding though was this wasn’t meant to be until next year, sadly as this is something Webflow are doing there isn’t really anything we can do here. Have you reached out to Webflow support to ask if the old api is still working?
Hey @Jon
I tested the v1 API for Webflow outside of n8n. And all things seemed to be working as expected. The v1 API isn’t expected to be changed or stop working till end of the year.
Not sure if something was changed on how n8n processes the v1 nodes. Would be great to get it fixed so that we can transition to the new Webflow nodes in the coming weeks.
Thanks!
