CSRF Token - I'm running out of options
Hello n8n community,
I’ve really been struggling, but I haven’t been able to connect n8n to the Paperless API. The issue is with the CSRF token. I managed to retrieve the token from the URL using an HTTP Request and then extract it from the HTML code, but the subsequent POST HTTP Request just doesn’t work no matter what I try.
My system consists of Docker containers for n8n (on-premise) and Paperless. Both containers communicate within a bridge network. I’ve attempted dozens of different configurations, yet the system consistently returns a 403 error and indicates something is wrong with the cookies. I’m slowly running out of options.
If anyone has successfully managed to connect to the Paperless API, I would be extremely grateful for any practical tips or guidance!
Regards
L.
Ok I found the solution. The API Error message said there is something wrong with CSRF. But actually it was a problem with URL format. Trailing slash was missing.
Hey @Lepoka,
Thanks for letting us know.
