Custom: Feishu (飞书) Node
Hey,
I created an Feishu (飞书) Node
It can help us realize message notification and online document editing.
More functions are being developed.
from doc : https://open.feishu.cn/document/server-docs/api-call-guide/calling-process/overview
https://www.npmjs.com/package/n8n-nodes-feishu-lite
Features
Address Book
  • Search for users
  • Get user information
  • Get user ID by phone number or email
Spreadsheet
  • Modify spreadsheet properties
  • Get spreadsheet information
  • Create spreadsheet
  • Get worksheet
  • Delete worksheet
  • Copy worksheet
  • Add worksheet
  • Query worksheet
  • Update rows and columns
  • Move rows and columns
  • Insert rows and columns
  • Delete rows and columns
  • Add rows and columns
  • Split cells
  • Set cell style
  • Replace cells
  • Merge cells
  • Find cells
  • Write data
  • Read a single range
  • Insert data
  • Write images
  • Append data
Message
  • Send message
  • Reply to message
  • Withdraw message
  • Forward message
  • Edit message
  • Send messages in batches
  • Withdraw messages in batches
cool, I love it
太棒了
Thank you for your support
Is there any plan to add support for “bitable” recently?
请问近期是否有计划添加多维表格的支持
I will do it
aleardy pulished
Much appreciated!
好人一生平安
I submitted a PR adding “wiki:getSpaceNode”.
However, I’d prefer it to be usable in the doc / bitable directly, but I don’t know how to implement the code. If possible, I hope it could be added. I’ve already filed an issue about this on GitHub.
我提交了一个 PR,添加了“wiki:getSpaceNode”。
然而,我更希望它能在文档/表格中直接使用,但不知道如何实现代码。如果可能的话,希望它能被添加。
关于这个问题我在 GitHub 上已经提交了一个 issue
I will do it.
feat: Add Task Nodes
Thank you for sharing. It’s incredibly amazing!
太棒了! 之前我一直都只能通过http请求来完成飞书的通知。
飞书项目的对接也非常有用。
牛逼格拉斯 :+1: :+1: :+1:
奇怪,为什么我配置了APP id 和secret key 后,获取结果只有[ { "name": "First item", "code": 1 }, { "name": "Second item", "code": 2 } ],是哪里不对么
专门注册上来喊你一声义父
感谢你的支持!!:joy::joy::joy:
Thanks, you’re NB~
:+1: :+1: :+1: :+1: :+1: :+1:
非常有用,帮助很大!
在starter版本怎么安装这个节点呀?
