Hey guys!
I’ve been working on a new Node but I realized that when I have a dateTime field which is marked as required, the n8n interfaz is not requiring it so, it’s like an optional one and the validation doesn’t work also.
In addition, I’ve found another node “Cisco Webex” with a dateTime field marked as required, however, I tested it and it doesn’t work.
My field has the following configuration:
displayName: 'From',
type: 'dateTime',
displayOptions: {
show: {
resource: [ 'task' ],
operation: [ 'getAll' ],
description: 'Some description here.',
required: true,
default: '',
Here are some images
Do you know what is happening? Something what I’m doing wrong?
Thank you
