Hey @Mthokozisi,
Welcome to the community ![]()
Your issue is not related to this topic and it is instead a misconfiguration in your .env file. Double check the DATA_FOLDER value and make sure it has the correct path to your n8n-docker-caddy folder. If you were doing the install as the root user it would possibly be something like /root/n8n-docker-caddy.
