Decode text base64
how can i use a function to decode text in base64
I had the same problem and it turned out you need a code node.
it worked perfectly, but how can I pass a list to get decoded?
I did like this, but it went wrong
So a couple of things I would change.
  1. Get rid of the array and json around the Buffer statement. This will get rid of the zero and “data” in your output.
  2. instead of “$input.first()” use “item”.
It’s worth noting that I haven’t tested the above but in general it should work.
