Subject: DeepSeek Node connection failure after updating to v2.12.3
Hello, I am reporting a regression issue with the ChatDeepSeek node.
Environment: Self-hosted (Docker)
n8n Version: v2.12.3 (Problem persists) / v2.2.6 (Works fine)
Issue Started: February 4th, 2026
Description: Since early February, the DeepSeek node has been unable to connect. While it functions normally on the older version (v2.2.6), it fails to authenticate or connect on the latest version (v2.12.3). I’ve waited for a fix in recent updates, but the issue still remains.
Could you please check if there were any breaking changes in the LangChain implementation or endpoint handling for DeepSeek in the newer releases?
