Good day, community!
Recently, I’ve been diving deep into scaling solutions for n8n, and I came up with a Docker Compose script to run in queue mode. I know many of you in the community are using self-hosted setups, so this should be super helpful!
Scaling Made Easy
You can add or remove worker nodes on the fly by simply adjusting the replicas count in your Docker Compose setup.
Handling External Access
If you’re self-hosting, you might need to expose your deployment to the outside world for things like webhooks.
But here’s the catch—if you’re running this on your laptop, maintaining a public IP while traveling is a hassle.
Enter ngrok!
I found a simple yet powerful solution by integrating ngrok, a globally distributed reverse proxy that secures, protects, and accelerates your applications.
This means seamless external connectivity, no matter where you are!
How to Get Started
Before jumping in, here’s what you need:
Sign up for ngrok and reserve a domain.
Update the WEBHOOK_URL and the url command in the ngrok service within the docker-compose file.
Pro Tip
If you’re on ngrok’s free plan, use:
https://localhost:5678for development.- The ngrok-provided domain only when external connectivity is required (e.g., adding credentials, authenticating Google Service Accounts).
Security First!
Replace the N8N_ENCRYPTION_KEY in your compose file!
The value must remain consistent across all instances.
Need to Send Emails?
Just add the N8N SMTP variables in the environment section of your services.
Docker Compose File
version: '3.8'
services:
n8n:
image: n8nio/n8n:latest
restart: always
ports:
- "5678:5678"
environment:
- DB_TYPE=postgresdb
- DB_POSTGRESDB_HOST=db
- DB_POSTGRESDB_PORT=5432
- DB_POSTGRESDB_DATABASE=n8n
- DB_POSTGRESDB_USER=n8n
- DB_POSTGRESDB_PASSWORD=n8n_pass
- EXECUTIONS_MODE=queue
- QUEUE_BULL_REDIS_HOST=redis
- N8N_HOST=localhost
- N8N_PROTOCOL=https
- WEBHOOK_URL=https://domain.url #place your ngrok domain here, use this url for the google service account concent screen redirect urls.
- N8N_ENCRYPTION_KEY= encryption_key #place your encrypton key here. longer the better but not too much
- N8N_RUNNERS_ENABLED=true
- OFFLOAD_MANUAL_EXECUTIONS_TO_WORKERS=true
- N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true
- N8N_DISABLE_PRODUCTION_MAIN_PROCESS=true
- N8N_ONBOARDING_FLOW_DISABLED=true
volumes:
- n8n_data:/home/node/.n8n
worker:
restart: always
environment:
- N8N_PROTOCOL=http
command: worker
deploy:
replicas: 2
webhook_processor:
image: docker.n8n.io/n8nio/n8n
restart: always
# ports:
# - 5679:5678
environment:
command: webhook
db:
image: postgres:15-alpine
restart: always
environment:
POSTGRES_USER: n8n
POSTGRES_PASSWORD: n8n_pass
POSTGRES_DB: n8n
volumes:
- db_data:/var/lib/postgresql/data
ngrok:
image: ngrok/ngrok:latest
command:
- "http"
- "http://host.docker.internal:5678"
- "--url=https://domain.url" #place your ngrok domain here
environment:
NGROK_AUTHTOKEN: authtoken #place your ngrok auth token here
ports:
- 4040:4040
redis:
image: redis:7-alpine
restart: always
volumes:
n8n_data:
db_data:
traefik_data:
A Bit About Me
I’ve been building automation solutions with n8n for over three years, and I run DevKrypt Solutions (devkrypt.com)—a startup focused on low-code automation with n8n and internal tool solutions with Windmill software.
Need help with your workflows, deployments, or automation strategies?
Let’s connect! I’d love to help you develop, consult and scale your solutions effortlessly.
(@kavishka)
