I have a strange issue. I have a simple setup, data comes via a webhook, go to the set module and then onto Airtable. This is a self hosted instance, so something may be wrong at the Firewall or the environment variables, however read on
It works perfectly if I use postman and works for both the test and Prod URL, but when I sent it data from the actual production - airtable creas empty rows (it only records the ‘record create time’ field. Everything else is blank. In the execution logs, I can see that the set node (2) received everything, but somehow the mapping did not work
Wow… it took me some time to understand what you are saying because I had copied the data from production into postman so how can they be different but then I realized I had added a set of square brackets [ ]… out of habit? I guess?
