Differences in results between Google Gemini Node and direct HTTP Request (Audio Analysis)
Question
I am trying to replicate the behavior of the native Google Gemini “Analyze Audio” node using a manual HTTP Request node(https://aiplatform.googleapis.com/v1/publishers/google/models/gemini-2.5-flash:generateContent) to hit Vertex AI, but I’m seeing significant differences in results and token usage. I have a few questions about how the native node is configured “under the hood”:
  1. What are the default Temperature, Top-P, and Top-K values used by the native node?
  2. Does the native node include any hidden System Instructions or “System Prompt” wrappers that aren’t visible in the UI?
  • n8n version: 1.123.18
  • Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
Hey @Levan, I checked your link, and it went to a invalid URL - “This aiplatform.googleapis.com page can’t be found
No webpage was found for the web address: https://aiplatform.googleapis.com/v1/publishers/google/models/gemini-2.5-flash:generateContent
HTTP ERROR 404”
I also did some research and also checked the N8N documentation for the node, and I couldn’t find any details on temperature, Top-P, Top-K either. However, this is just a guest but the default might match the default through the actual correct URL, though I’m not sure.
  1. I didnt see any system instructions but you can use the text input to help describe the audio, for a better response. You can also set the max tokens it returns for the analysis description.
Hope this Helps! If you have any more questions, feel free to ask!
Hi @Levan, welcome!
The Gemini node does not use the Vertex endpoints (it uses https://generativelanguage.googleapis.com,
As per the source code:
The only parameter sent is maxOutputTokens, which is already an option in the node UI,
also the Text Input is sent as part of the body content.
I believe all other settings (Top-P, Top-K, etc.) use the defaults for the /v1beta/${model}:generateContent endpoint..
