I’m using n8n in a Docker-Compose setup with NGINX as a reverse proxy. The editor loads fine at the configured URL, and workflows can be activated, but webhooks do not respond to test events sent to the expected URL.
There’s no direct error visible when testing the webhook, but the following logs were captured:
- n8n Logs:
csharp
Copy code
Error: nodes package n8n-nodes-base is already loaded.
Please delete this second copy at path /home/node/.n8n/nodes/node_modules/n8n-nodes-base
- NGINX Logs:
csharp
Copy code
recv() failed (104: Connection reset by peer) while reading response header from upstream
Here’s a simple workflow with a webhook trigger for testing purposes:
json
Copy code
When testing the webhook, there’s no response from the endpoint, and no logs are triggered in the n8n editor.
- n8n version: 1.72.1
- Database (default: SQLite): SQLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): Docker-Compose
- Operating system: Ubuntu 22.04
Additional Details
Here’s the docker-compose.yml file (sanitized):
yaml
Copy code
version: "3.7"
services:
n8n:
image: n8nio/n8n
ports:
- "5678:5678"
volumes:
- /path/to/local/data:/home/node/.n8n
environment:
- N8N_PROTOCOL=https
- N8N_HOST=example.com
- WEBHOOK_URL=https://example.com/
restart: unless-stopped
Here’s a snippet of the NGINX configuration for the proxy (sanitized):
nginx
Copy code
server {
listen 80;
server_name example.com;
location / {
proxy_http_version 1.1;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
listen 443 ssl;
ssl_certificate /path/to/certificate.crt;
ssl_certificate_key /path/to/private.key;
