DOCKER Write permission issue : The file "/home/node/data/newsletter.txt" is not writable
Hello all. I think there is a real topic here. So many similar topic but still the same problem. After trying almost everything I saw on the other topics, I have no choice but to pos here because the issue is not resomve on my end
I’m trying to write a file to disk but it fails, supposedly because of permissions
To create the container, I run this command :
docker run -it --rm --name n8n -p 5678:5678 -e GENERIC_TIMEZONE=Europe/Paris -e TZ=Europe/Paris -e N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true -e N8N_RUNNERS_ENABLED=true -v n8n_data:/home/node/.n8n --mount type=bind,source=C:\Users\Teo\Documents\output_volume,target=/output docker.n8n.io/n8nio/n8n
When that command is executed, I get the following directory structure inside the container :
The error message I get in n8n is : (notice I use ./data/newsletter.txt which makes it go as expected to /home/node/data)
The file “/home/node/data/newsletter.txt” is not writable.
  • n8n version: 2.1.5
  • Operating system: Windows
Hi @Teo25,
Did you following documentation for this section adding the path to your env vars?
This is a new requirement since version 2
Hi @Wouter_Nigrini
Thanks for your reply
I tried to set N8N_RESTRICT_FILE_ACCESS_TO and this gave me the following error
The docker run command is
docker run -it --rm --name n8n -p 5678:5678 -e GENERIC_TIMEZONE=Europe/Paris -e TZ=Europe/Paris -e N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true -e N8N_RUNNERS_ENABLED=true -e N8N_RESTRICT_FILE_ACCESS_TO=/output -v n8n_data:/home/node/.n8n --mount type=bind,source=C:\Users\Teo\Documents\output_volume,target=/output docker.n8n.io/n8nio/n8n
As you can see, I only added the following option to the command
The filesystem permissions are the same as in my original post
Ok so I was able to replicate the exact error. I then deleted the write node and add it again and the error went away. Not sure why the node was broken but try recreating the node. The docker settings looks good
Glad it worked for you. But for me, it’s still the same issue. I deleted the node. Stopped the container. Restarted the container and recreated the node. But still, the same error persists. I don’t even know if its n8n bug or a docker quirky configuration thats bogging me
