Duplication Execution Issue: 181 Items Requested, 542 Executions Triggered with Execute Workflow (Queue Mode)
Hello everyone,
I’m encountering a strange issue with n8n and would appreciate your help in resolving it.
Context
  • I have a parent workflow that triggers a child workflow (named sendMessage) using the Execute Workflow node.
  • Normally, the parent sends 181 items to the child workflow, so I expect to see 181 executions in sendMessage.
  • Problem: In the logs, I observe that sendMessage has been executed ~ 542 times for the same parent execution (same ID).
  • Resulting Issue: There is an unexpected surplus of duplicate executions.
Let explain what hapen :
My trigger node, “sendMessage”, from the workflow “Launch_send_message”, sends 181 items to the workflow “sendMessage”.
In the “sendMessage” workflow, I receive the data once for each item (so it should normally be 181 executions) from the node “Launch_Send_message”.However, instead of 181 executions, there were approximately 542 executions, including duplicate executions with the same data, the same IDs, and identical information.
Do you know why this is happening?
Environment
  • n8n is deployed using Docker and Docker Compose.
  • Execution Mode: EXECUTIONS_MODE=queue.
  • 1 main n8n container (handles the interface, etc.) and 6 workers (n8n-worker-X), as well as n8n-webhook-X services.
  • Database: Postgres 16.
  • Queue: Redis 6.
  • Proxy: Traefik.
What I Have Already Checked
  • The parent workflow does not contain any loops or multiplier processes (e.g., misconfigured Split in Batches).
  • In the logs, all 542 executions of sendMessage are linked to the same parent executionId.
  • I noticed that in the main container, I did not explicitly set N8N_DISABLE_PRODUCTION_MAIN_PROCESS=true.
    • This means the main process might also be executing the 181 items in addition to the workers.
  • I am using multiple workers, which could be further multiplying the executions.
Questions
  1. Why is n8n executing the same items multiple times?
  2. Are there specific environment variables (e.g., EXECUTIONS_WORKER=queue, EXECUTIONS_WORKER_PROCESS, N8N_DISABLE_PRODUCTION_MAIN_PROCESS=true, QUEUE_HEALTH_CHECK_ACTIVE, etc.) that I might have forgotten or misconfigured?
  3. There are several environment variables available, but which ones should I use? n8n Queue Mode Environment Variables Documentation
Thank You in Advance
Any suggestions or potential solutions are welcome!
If you have examples of functional docker-compose configurations in queue mode with multiple workers, I would greatly appreciate it.
Thank you for your assistance!
Additional Information:
For reference, here is my current docker-compose.yml configuration:
version: '3.8'
volumes:
  db_storage:
  n8n_storage:
  redis_storage:
  traefik_data:
  ollama_storage:
x-shared: &shared
  restart: always
  image: docker.n8n.io/n8nio/n8n
  environment:
    - DB_TYPE=postgresdb
    - DB_POSTGRESDB_HOST=postgres
    - DB_POSTGRESDB_PORT=5432
    - DB_POSTGRESDB_DATABASE=${POSTGRES_DB}
    - DB_POSTGRESDB_USER=${POSTGRES_NON_ROOT_USER}
    - DB_POSTGRESDB_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
    - EXECUTIONS_MODE=queue
    - QUEUE_BULL_REDIS_HOST=redis
    - QUEUE_HEALTH_CHECK_ACTIVE=true
    - N8N_ENCRYPTION_KEY=${ENCRYPTION_KEY}
    - N8N_BASIC_AUTH_ACTIVE=true
    - N8N_BASIC_AUTH_USER=${N8N_BASIC_AUTH_USER}
    - N8N_BASIC_AUTH_PASSWORD=${N8N_BASIC_AUTH_PASSWORD}
    - N8N_HOST=n8n.exemple.fr
    - N8N_PORT=5678
    - N8N_PROTOCOL=https
    - WEBHOOK_URL=https://n8n.exemple.fr/
  links:
    - postgres
    - redis
  volumes:
    - n8n_storage:/home/node/.n8n
  depends_on:
    redis:
      condition: service_healthy
    postgres:
x-ollama: &service-ollama
  image: ollama/ollama:latest
  container_name: ollama
  restart: unless-stopped
  volumes:
    - ollama_storage:/root/.ollama
services:
  traefik:
    image: traefik:latest
    container_name: traefik
    networks:
      - default
    command:
      - "--api=true"
      - "--api.insecure=true"
      - "--providers.docker=true"
      - "--providers.docker.exposedbydefault=false"
      - "--entrypoints.web.address=:80"
      - "--entrypoints.web.http.redirections.entryPoint.to=websecure"
      - "--entrypoints.web.http.redirections.entrypoint.scheme=https"
      - "--entrypoints.websecure.address=:443"
      - "--certificatesresolvers.mytlschallenge.acme.tlschallenge=true"
      - "--certificatesresolvers.mytlschallenge.acme.email=${SSL_EMAIL}"
      - "--certificatesresolvers.mytlschallenge.acme.storage=/letsencrypt/acme.json"
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - traefik_data:/letsencrypt
      - /var/run/docker.sock:/var/run/docker.sock:ro
  postgres:
    image: postgres:16
    restart: always
    environment:
      - POSTGRES_USER=${POSTGRES_USER}
      - POSTGRES_PASSWORD=${POSTGRES_PASSWORD}
      - POSTGRES_DB=${POSTGRES_DB}
      - POSTGRES_NON_ROOT_USER=${POSTGRES_NON_ROOT_USER}
      - POSTGRES_NON_ROOT_PASSWORD=${POSTGRES_NON_ROOT_PASSWORD}
    volumes:
      - db_storage:/var/lib/postgresql/data
      - ./init-data.sh:/docker-entrypoint-initdb.d/init-data.sh
    healthcheck:
      test: ['CMD-SHELL', 'pg_isready -h localhost -U ${POSTGRES_USER} -d ${POSTGRES_DB}']
      interval: 5s
      timeout: 5s
      retries: 10
  redis:
    image: redis:6-alpine
    restart: always
    volumes:
      - redis_storage:/data
    healthcheck:
      test: ['CMD', 'redis-cli', 'ping']
      interval: 5s
      timeout: 5s
      retries: 10
  n8n:
    <<: *shared
    labels:
      - "traefik.enable=true"
      - "traefik.http.routers.n8n.rule=Host(`n8n.exemple.fr`)"
      - "traefik.http.routers.n8n.entrypoints=websecure"
      - "traefik.http.routers.n8n.tls=true"
      - "traefik.http.routers.n8n.tls.certresolver=mytlschallenge"
    deploy:
      resources:
        limits:
          cpus: "1"
  n8n-worker-1:
    <<: *shared
    command: worker
    deploy:
      resources:
        limits:
          cpus: "1"
    depends_on:
      - n8n
  n8n-worker-2:
    <<: *shared
    command: worker
    deploy:
      resources:
        limits:
          cpus: "1"
    depends_on:
      - n8n
  n8n-worker-3:
    <<: *shared
    command: worker
    deploy:
      resources:
        limits:
          cpus: "1"
    depends_on:
      - n8n
  n8n-worker-4:
    <<: *shared
    command: worker
    deploy:
      resources:
        limits:
          cpus: "1"
    depends_on:
      - n8n
  n8n-worker-5:
    <<: *shared
    command: worker
    deploy:
      resources:
        limits:
          cpus: "1"
    depends_on:
      - n8n
  n8n-worker-6:
    <<: *shared
    command: worker
    deploy:
      resources:
        limits:
          cpus: "1"
    depends_on:
      - n8n
  n8n-webhook-1:
    <<: *shared
    command: webhook
    deploy:
      resources:
        limits:
          cpus: "0.5"
    depends_on:
      - n8n
  n8n-webhook-2:
    <<: *shared
    command: webhook
    deploy:
      resources:
        limits:
          cpus: "0.5"
    depends_on:
      - n8n
  ollama-cpu:
    <<: *service-ollama
version: ‘3.8’
Databse : postgres
EXECUTIONS_PROCESS : queue with redis
Running n8n via Docker
on linux
Hello, community!
I have successfully reproduced my bug multiple times.
I was able to replicate the issue using the basic queue mode installation of n8n with workers:
Bug Description:
  • The error occurs when a parent node triggers an execution via cron or trigger scheduler (i.e., when the parent node starts automatically and not manually).
  • The error only occurs when the parent node calls sub-workflows in “Wait for Each Item” mode. It does not happen when using the “Don’t Wait for Sub-workflow Completion” mode.
  • We suspect the error happens only when the child workflow contains “Wait” nodes exceeding 60 seconds. In our case, the wait nodes were set to 60 minutes.
Here are four real screenshots showing the executions and the error.
For now, our approach to fixing the issue is as follows:
Using the “Don’t Wait for Sub-workflow Completion” mode to launch sub-worflow.
If the number of incoming executions exceeds the number of executions sent by the parent node, the execution is stopped.
An error notification is sent to Discord to report this inconsistency.
Update execution tracking variables to ensure accurate monitoring.
The parent node must pass its execution count to the child node, which then triggers the send message action.
  1. Using n8n Environment and Execution Variables
  2. Execution Count Verification
  3. Updating Variables
  4. Transmitting Execution Count
Launch_Send_Message
sendMessage
analyse-bug
