ElevenLabs Voice Agents Are So Easy to Build (No Code!)
Nate Herk writes:
In this video, I’ll show you how to create a conversational voice AI agent using ElevenLabs and n8n to help you send emails—no coding required! We’ll walk through connecting key tools and functions step-by-step to bring this build to life. By the end of this tutorial, you’ll know exactly how to set up your own voice AI workflow and start testing it yourself. Whether you’re new to voice automation or looking to enhance your productivity, this guide will make it simple and fun.
:link: Tools We’ll Use:
  • ElevenLabs for voice generation
  • n8n for the email AI Agent
That’s a great workflow! I only have two questions about it:
  1. If I have several calls at the same time, does the AI ​​agent manage to differentiate between them? If so, how?
  2. Do you have experience with complex conversation processes where I might need several AI nodes because otherwise the prompt would be too big (so-called “conversational flows”)
I love this, but not sure where to put my issue. I have n8n cloud, and it can’t find elevenlabs node. I have n8n local on my windows machine, and it finds elevenlabs, but can’t install. command failed: tar -xzf. I’ve got cygwin, but it still errors. Sorry if wrong place to post this.
