Email Read IMAP Node works sometimes
FWIW, I’m still seeing this happen on 0.127.0 :confused:
Welcome to the community @t10i !
Please make sure to add the “Force Reconnect” option:
Will give that a whirl, thanks @jan !
That should solve your problem. To be sure you can also set it to a shorter amount like 10 or 5 if you feel the disconnects happen very frequently.
So far this seemed to have resolved the issue, thanks!
Hello,
In my case, I deactivate POP/IMAP into Avast Antivirus and run correctly.
Welcome to the community @TITO_BINBIN
Thanks for sharing
