joey
February 28, 2021, 1:09am
1
I am running the official docker image 0.109.0 and am having some trouble adding an imap node. Currently if I
Create a new workflow
Add the emailreadimap node
Choose credentials same issue with both
Gmail - using app password
Yahoo - using app password
Click execute node
With modal open it hangs and same if I close it
Previously I was getting the ssl cert error which I resolved by changing
// old code
tlsOptions = {};
// new code
tlsOptions = { rejectUnauthorized: false };
as shown in this thread
jan
February 28, 2021, 11:21am
2
Welcome to the community @joey !
The node does not “hang” it waits for an email to arrive. As soon as it receives one, the node will resolve.
joey
February 28, 2021, 1:33pm
3
What does it mean when the animation stops but the workflow is active?
jan
February 28, 2021, 1:41pm
4
Those are two different things.
When the workflow is active it does its job in the background. You will never see the data directly in the editor. You will only see it in the execution history if you save it.
Only if you execute the workflow manually via the UI will you see the data in it.
