Hi everyone ![]()
I’m working on a workflow where I process company data from an Excel file that looks like this:
"category_id": 483,
"country_id": 75,
"country_code": "FR",
"country_name": "France",
"Identifiant Kompass": "FRXXXXXXX",
"Nom de l'entreprise": "Entreprise A",
"Numéro d’enregistrement (Siret, Siren…)": "XXXXXXXXX XXXXX",
"Numéro de TVA intracommunautaire": "FRXX XXXXXXXX",
"Email": "",
"Numéro de téléphone": "+33 XXXXXXXXX",
"Site web": "https://www.entreprise-a.com",
"Rue": "Adresse Rue A",
"Complément d'adresse": "Complément A",
"Code postal": "XXXXX",
"Ville": "Ville A",
"Département/District": "Département A",
"Région": "Région A",
"Pays": "France",
"Effectif entreprise": "De 20 à 49",
"company_size": "20_49",
"Tranche du CA brut": "De 10 à 25 millions EUR",
"revenue_range": "10m_25m",
"Code NAF 2008": "XXXXZ",
"employees": [
"Prénom": "Prénom1",
"Nom": "Nom1",
"Email direct dirigeant*": "[email protected]",
"Libellé fonction locale": "Fonction 1",
"Civilité": "M."
"Prénom": "Prénom2",
"Nom": "Nom2",
"Libellé fonction locale": "Fonction 2",
"Civilité": "M."
"Prénom": "Prénom3",
"Nom": "Nom3",
"Libellé fonction locale": "Fonction 3",
"Civilité": "M."
"Prénom": "Prénom4",
"Nom": "Nom4",
"Libellé fonction locale": "Fonction 4",
"Civilité": "Mme"
"category_id": 483,
"country_id": 75,
"Nom de l'entreprise": "Entreprise B",
"Email": "[email protected],[email protected]",
"Site web": "https://www.entreprise-b.fr",
"Rue": "Adresse Rue B",
"Complément d'adresse": "Complément B",
"Ville": "Ville B",
"Département/District": "Département B",
"Région": "Région B",
"Pays": "France",
"Effectif entreprise": "De 0 à 9",
"company_size": "0_9",
"Tranche du CA brut": "De 1 à 2 millions EUR",
"revenue_range": "1m_2m",
"Code NAF 2008": "XXXXC",
"employees": [
"Nom": "Nom1",
"Civilité": "M"
"category_id": 483,
"country_id": 75,
"Nom de l'entreprise": "Entreprise C",
"Email": "[email protected],[email protected],[email protected],[email protected]",
"Site web": "https://www.entreprise-c.fr",
"Rue": "Adresse Rue C",
"Complément d'adresse": "Complément C",
"Ville": "Ville C",
"Département/District": "Département C",
"Région": "Région C",
"Pays": "France",
"employees": [
"Nom": "Nom1",
"Civilité": "Mme"
"Nom": "Nom2",
"Civilité": "Mme"
"category_id": 483,
"country_id": 75,
"Nom de l'entreprise": "Entreprise D",
"Email": "",
"Site web": "https://www.entreprise-d.com",
"Rue": "Adresse Rue D",
"Complément d'adresse": "Complément D",
"Ville": "Ville D",
"Département/District": "Département D",
"Région": "Région D",
"Pays": "France",
"Tranche du CA brut": "De 5 à 10 millions EUR",
"revenue_range": "5m_10m",
"employees": [
"Nom": "Nom1",
"Civilité": "M."
"Nom": "Nom2",
"Civilité": "M."
"category_id": 483,
"country_id": 75,
"Nom de l'entreprise": "Entreprise E",
"Email": "",
"Site web": "https://www.entreprise-e.fr/",
"Rue": "Adresse Rue E",
"Complément d'adresse": "",
"Ville": "Ville E",
"Département/District": "Département E",
"Région": "Région E",
"Pays": "France",
"Effectif entreprise": "De 100 à 249",
"company_size": "100_249",
"employees": [
"Nom": "Nom1",
"Civilité": "M."
What I’m trying to do
I want to:
- Read this Excel data.
- Check each company’s SIRET in Odoo via an HTTP Request node.
- If found, get the company’s ID.
- If not found, create it and get its ID.
- Enrich each original company object with that corresponding ID (e.g.,
odoo_company_idfield).
The issue
Everything works fine except the final enrichment step.
If companies are both found and created in the same execution, the result mapping back the Odoo IDs to the original companies gets out of sync. IDs are not added to the correct company objects — the indexes seem mismatched.
What I tried (but didn’t help)
- I explored solutions around referencing previous data:
- Tried combining streams back together after
IfandCreatebranches. - Also faced filtering issues with the Odoo node when using non-string values: Odoo Node - filter "in" operators return an Error
What I’m looking for
How can I recombine the results from both the “Found” and “Created” paths back into the original data while preserving the order?
Should I store metadata early on? Use Merge node in a clever way? Am I missing a good n8n pattern for this?
Thanks a lot for any ideas ![]()
Workflow example
In this example, I have appointed fake results from HTTP requests. How would you do it ?
These should be the end results :
- A → 0
- B → 1
- C → 3
- D → 4
- E → 2
But as we can see, it ends up being :
- A → 3
- B → 4
- C → 0
- D → 1
- E → 2
