Error and success for subworkflow execution node bug
Hello, I am receiving simultaneous output from the sub-workflow for success and failure at the same time. How is this possible and how can it be fixed?
  • n8n version: Version 2.2.5
  • Database (default: SQLite): sqlite
  • n8n EXECUTIONS_PROCESS setting (default: own, main): not sure, probably default
  • Running n8n via (Docker, npm, n8n cloud, desktop app): docker, hostinger
  • Operating system: server ubuntu, I’m on mac os
Hi @JSA i think substituting a ‘Wait’ node on your sub-workflow with a Code node that might implements a delay, this can prevent a n8n bug that throws when a sub-workflow waits, it returns both success and error, let me know if this helps.
There is no wait node in my wf. Not sure what do you mean
Ah i see @JSA just ensure the sub-workflow only ever reaches an end once, and prevent it from completing normally and throwing an error. Either catch or convert errors inside the sub-workflow, so the Execute Workflow node returns one clear result.
My sub workflow have one single path. So there is another thing/ I search the web and it’s looks like because node have on the same time on “always Output data” and “continue on error with error output”, it’s caused double path.
