Error: Command "start" not found problem
I’m trying to install the latest version n8n but I got error:
Error: Command “start” not found
I installed by npm so I did:
npm install n8n -g
n8n
then the error shows:
No encryption key found - Auto-generating and saving to: /root/.n8n/config
the no encryption only appears once but the Command "start" not found will always appear when using n8n command
  • n8n version: 2.28.7
  • Database (default: SQLite):default
  • n8n EXECUTIONS_PROCESS setting (default: own, main):default
  • Running n8n via (Docker, npm, n8n cloud, desktop app):npm
  • Operating system:Ubuntu 24.04LTS
Hi @Ruriko
This may help
Doesn’t work even though it is mentioned 2.28.6 should of been patched
So what did you do?
Reinstalled OS so it’s fresh again and installed nodejs v24.18.0 and finally this:
npm install -g n8n@2.28.6
n8n
Hi @Ruriko ,
This error usually occurs when the global npm installation is corrupted or fails to bind the executable binaries during installation on Ubuntu properly.
Here is the step-by-step solution to fix this:
Step 1: Check your Node.js version
First, make sure you are running a supported Node.js version n8n requires Node v18.x or v20.x.
node -v
If your version is older or unsupported, update Node.js first.
Step 2: Clean reinstall n8n
Completely remove the broken global installation and reinstall it cleanly:
sudo npm uninstall -g n8n
npm cache clean --force
sudo npm install -g n8n --unsafe-perm=true
Step 3: Run n8n
Once installed, try running it again:
n8n
Alternative Quick Test:
If you still get the same error, try running n8n directly via npx to bypass global linking issues:
npx n8n
Note: If you plan to run n8n long-term on Ubuntu 24.04 LTS, setting it up via Docker is highly recommended for better stability.
Let me know if this resolves the issue for you!
Nope it still doesn’t work even with the alternative quick test and I also tested 2.28.7 which came out like an hour ago. Oh i forgot to mention that when I first used n8n it will say:
but if I repeat entering n8n it only says Error: Command "start" not found so No encryption key found - Auto-generating and saving to: /root/.n8n/config only appears once.
My temp solution is to downgrade back to 2.26.4 :frowning:
Thanks for the extra details @Ruriko ! That info about /root/.n8n/config and version 2.26.4 working is super helpful.
This confirms it is a regression in the CLI argument parser in recent 2.28.x builds where invoking n8n alone no longer automatically aliases to the start command under certain node environments.
Can you try these steps?
1. Run the explicit command
Instead of running just n8n, try executing the full command:
n8n start
(Or npx n8n start)
2. Clear the auto-generated config (Backup first)
Since the config was created during the failed initial run of 2.28.x, it might contain a broken CLI state. Rename the folder and try again:
mv /root/.n8n /root/.n8n_backup
n8n start
3. Run as a non-root user (Recommended)
Running n8n directly as root can cause node permission overrides and CLI wrapper conflicts on Ubuntu 24.04. It’s best practice to create/use a standard system user to run n8n start.
If running n8n start explicitly works, it confirms the default CLI alias bug in 2.28.x! Let me know if that gets it past the error.
Thanks!
I tried n8n start but still doesn’t work and tried with a non-root account and still same error
Did all the recommendations. Even the downgrade does not work for me..
Well it looks like I’m not the only one with the same problem Can't access n8n in windows after upgrade: Error: Command "start" not found · Issue #33462 · n8n-io/n8n · GitHub
