Hello! Could use some help!
I am using the APITemplate.io node, trying to create an image where I am passing through the text for the template.
When I run the node, I get the error “ERROR: Could not get parameter “options”!”
Here is the workflow. It only has a Start node and an APITemplate.io node:
The output of the final node:
Error: Could not get parameter "options"!
at getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/src/NodeExecuteFunctions.js:687:15)
at Object.getNodeParameter (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/src/NodeExecuteFunctions.js:889:24)
at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/ApiTemplateIo/ApiTemplateIo.node.js:413:46)
at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/src/Workflow.js:524:37)
at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/src/WorkflowExecute.js:447:62
at processTicksAndRejections (node:internal/process/task_queues:96:5)
Running n8n on a raspberry pi Zero w 2, Version 0.152.0, npm inside pm2
Any help much appreciated!
