Error in running a loop
We tried to build a loop to query with some data in our internal server within the past 30 days, to avoid a large amount of data, we tried to separate it into 30 times(querying the data day by day, nearly 30-60 items each), the workflow has worked before, however, after we update the n8n version to the latest version, the workflow crashed every time we execute it, the UI was not responsible and the workflow would never be finished. The issue remains even we added the memory and adjusted with the NODE_OPTIONS=–max_old_space_size variable. What we did is we tried to roll back the n8n version to 1.10.0 and it works finally.
The workflow crashed after the execution. No error message could be shown and the docker crashed and restarted afterward, however, we could not reach the UI again after it crashed.
Below please find our workflow
No output could be found as it crashed.
  • **n8n version: 1.11.1
  • **Database (default: SQLite): SQLite
  • **n8n EXECUTIONS_PROCESS setting (default: own, main): main
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
  • **Operating system: Ubuntu
Hi @ansonchl :wave: Welcome to the community :tada:
Thanks for posting all of that information - maybe @netroy can shed some light here on as to why this is working for you in 1.10.1 but not 1.11.1, and what may have changed to memory consumption being increased :bowing_man:
