Error in sub node 'Anthropic chat model' or 'openai chat model'
Please help.
I’m getting this message:
Invalid ‘tools[0].function.name’: string does not match pattern. Expected a string that matches the pattern ‘[1]+$’.
I’m using openai (or anthropic) as the chat model and all I did was connect a google mail module to the AI Agent. If I create the scenario with a “google calendar”, it works fine. Also, if i connect a “read emails” module, no problems. Only as I connect a “send emails” module, it stops working. It somehow gets so messed up, that I have to delete the AI Agent and start over.
  • **Database (default:
  • **n8n EXECUTIONS_PROCESS setting (default
  • **Running n8n via n8n cloud,
  1. a-zA-Z0-9_- ↩︎
Hi @itssssschris
Thanks for posting here and welcome to the community! :raised_hands:
Could you please share your workflow? This would to debug by seeing your current configuration.
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
Thanks!
I just had the same exact issue. Watching this!
I have this issue as well… following!
N8N tech support says it’s not a bug.
FYI I was getting this same error. I found what the culprit was in my case. I had a google drive tool on my bot that I named “F&O Documentation” When I change this to “D365 Finance Documentation” I stopped getting the error.
TLDR do not use special characters in the names of your nodes.
