Hello, I have a problem converting date and time from unix ms timestamp to normal timestamp using date and time node as shown below.
if i use the following website to convert the same number, i am getting the correct timestamp.
I assume that it is not a UNIX timestamp rather a JavaScript one. The difference is that the UNIX timestamp is in seconds and the JavaScript one in ms. Meaning you have to divide it by 1000.
Hello @jan , thank you for helping out.
i read the developer guide , and it states that is it in unix milisecond timestamp.
and I have selected to "convert from " ms timestamp by selecting “x”
some update. I tried with a new node it is working now…
Glad to hear that you got it working!
Eu estou com o mesmo problema, poderia mostrar a solução?
Hi @Jon,
Of course!
Here’s the input:
"Id": "18162",
"Start_time": 1663801200000,
"End_time": 1663804800000,
"Room": " The Stadium"
"Id": "18173",
"Start_time": 1663797600000,
"End_time": 1663801200000,
"Id": "18178",
"Start_time": 1663804800000,
"End_time": 1663808400000,
"Id": "18182",
"Room": " The Garden"
and there is the output:
"Id": "18162",
"Room": " The Stadium",
"data": "54693/10/05"
"Id": "18173",
"data": "54693/08/24"
"Id": "18178",
"data": "54693/11/16"
"Id": "18182",
"Room": " The Garden",
The “Start_time” from the input is the result put in the “data” column in Output.
It seems that I need it to be converted to RFC 3339 (2022-09-22T20:24:54+00:00) so my calendar can accept the format.
Hey @Cizco,
That was an interesting distraction, I am not sure what is going on but… if you add .toString()
to the end of the expression it will work. I have created a bug ticket internally which we will be tracking under N8N-4737
FYI I am running 0.201.0 on my own server and this bug still exists. i added the .toString() and it solved the problem.
