[ERROR: invalid syntax] agent prompt - I need help
since I update the n8n version I facing some troubles with the agent prompt:
The error: [ERROR: invalid syntax]
version: 1.95.3
I need help
Hi @Gonzalo_Alegre
Can you upload your n8n workflow so we can replicate the error?
pasteworkflow
