Uneerup
February 24, 2025, 11:13am
1
Hi
After upgrading I suddenly receive this error on a workflow that have been running for months now.
Using the item method doesn’t work with pinned data in this scenario. Please unpin ‘Convert to File’ and try again.
Does anybody know why this suddenly happens? It should not use any pinned data when not in test.
n8n version: Latest
Database (default: SQLite):
Running n8n via (n8n cloud):
Operating system:
n8n
2
n8n version:
Operating system:
Uneerup
February 24, 2025, 12:09pm
3
Hi again
I can see the workflow has trouble getting data from a previous node (8 nodes back) It is saying
Can’t determine which item to use
Please note: there is only one.
As I said before, This has worked for months, but now it is suddenly failing.
Uneerup
February 24, 2025, 12:21pm
4
Ok. Now I have narrowed it down. After the “Convert to file” node, it is no longer possible to get data from a node 8 nodes back.
Can someone at N8N look into that?
Uneerup
February 24, 2025, 4:47pm
6
Hi again
Thanks for your reply. I have investigated it further.
It looks like, that it makes an error if you have a “Split out” node followed by a “convert to file” node. Please see the example I have made for proving this error. The error is “[ERROR: Can’t determine which item to use]” So it has nothing to do with pinned data
barn4k
February 24, 2025, 7:42pm
7
hello @Uneerup
I didn’t have any errors with the workflow. But when the outputted items doesn’t match then you can’t access the first one with the $().item property. It’s incorrect, as there is no “pair” for the second item and you have to use either $().first().json or $().last().json property instead
Uneerup
February 24, 2025, 8:34pm
8
Hi @barn4k
Are you sure you are running on the latest version?
Please see the attached screenshot. It makes an error for me. Please note that it was working before upgrading.
barn4k
February 24, 2025, 9:00pm
9
ah, yeah. It was a previous version. Get it broken on the 1.79.3.
Well, this is indeed strange. Will ping someone from n8n to take a look.
I’m assuming that it doesn’t like that part
But I don’t know why it’s ok with the expression of the Edit Fields2 node, as it has the pretty same behavior
Uneerup
February 24, 2025, 9:17pm
10
Well I hope @n8n will prioritize it because it is a fundamental part of the normal use of N8N.
same error here! Using the item method doesn't work with pinned data in this scenario. Please unpin 'Convert to File' and try again.
barn4k
February 25, 2025, 11:31am
12
Please, update to the v1.80.3. It should be fixed there.
Uneerup
February 25, 2025, 11:48am
13
Done! And it works - thanks
langtry
February 28, 2025, 9:03pm
14
I’m still having this issue. Upgraded to 180.5 this morning and the error remains. Didn’t have any issues like this prior a few days ago.
Oh no!
@barn4k please be aware of the last post. I will wait upgrading until the error has been fixed again.
@langtry thanks for sharing.
barn4k
March 4, 2025, 8:26am
16
with v1.81.4 everything is ok
Nope. I’m getting the same error and I just upgraded to the latest version.
Frustrating, as it was working, until it wasn’t. The node it’s saying is pinned, isn’t, and never has been. The node it’s actually needing to get data from is not pinned.
A very frustrating error.
I’ve now unpinned everything - then gone an pinned and unpinned every node, upgraded to latest version, and it’s still happening. What a pain.
barn4k
March 10, 2025, 5:54am
19
@karatechopping
Please, share the workflow.
Solved it eventually. Used .first() instead of .item and it worked. It was a lack of understanding on my part!
