Hi @jan. I also got this error message:
Preformatted text
The webhook path [77b3afad-5fdc-4884-9b24-5e177ae0cb25/webhook] and method [POST] already exist.*
Problem
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"authentication": "oAuth2",
"team": "8426050",
"events": [
"taskStatusUpdated"
"filters": {}
"name": "ClickUp Trigger",
"type": "n8n-nodes-base.clickUpTrigger",
"typeVersion": 1,
"position": [
440,
300
"webhookId": "77b3afad-5fdc-4884-9b24-5e177ae0cb25",
"notesInFlow": true,
"credentials": {
"clickUpOAuth2Api": "OAuth2 [email protected]"
"notes": "When task status is updated..."
"parameters": {
"operation": "update",
"id": "={{$node[\"ClickUp Trigger\"].json[\"task_id\"]}}",
"updateFields": {
"status": "={{$node[\"ClickUp Trigger\"].json[\"history_items\"][0][\"before\"][\"status\"]}}"
"name": "ClickUp",
"type": "n8n-nodes-base.clickUp",
"typeVersion": 1,
"position": [
800,
210
"credentials": {
"parameters": {
"conditions": {
"string": [
"value1": "=status",
"value2": "next actions"
"name": "IF",
"type": "n8n-nodes-base.if",
"typeVersion": 1,
"position": [
620,
300
"notes": "If task status = Next Action"
"parameters": {},
"name": "NoOp",
"type": "n8n-nodes-base.noOp",
"typeVersion": 1,
"position": [
810,
400
"parameters": {
"channel": "n8n2",
"text": "=ClickUp task https://app.clickup.com/----/v/l/li/{{$node[\"ClickUp\"].parameter[\"id\"]}} {{$node[\"ClickUp Trigger\"].parameter[\"events\"][0]}} to Next Actions",
"attachments": [],
"otherOptions": {}
"name": "Slack",
"type": "n8n-nodes-base.slack",
"typeVersion": 1,
"position": [
990,
210
"credentials": {
"slackApi": "Forwardjump Slack"
"parameters": {
"conditions": {
"string": [
"value1": "={{$node[\"ClickUp Trigger\"].json[\"history_items\"][0][\"before\"][\"status\"]}}",
"value2": "waiting on"
"name": "IF1",
"typeVersion": 1,
"position": [
970,
400
"notes": "If Task status = Waiting on"
"parameters": {
"updateFields": {
"name": "ClickUp1",
"typeVersion": 1,
"position": [
1150,
380
"credentials": {
"parameters": {
"channel": "n8n2",
"text": "=ClickUp task https://app.clickup.com/8426050/v/l/li/{{$node[\"ClickUp\"].parameter[\"id\"]}} {{$node[\"ClickUp Trigger\"].parameter[\"events\"][0]}} to Waiting On",
"attachments": [],
"otherOptions": {}
"name": "Slack1",
"typeVersion": 1,
"position": [
1320,
380
"credentials": {
"connections": {
"ClickUp Trigger": {
"main": [
"node": "IF",
"type": "main",
"index": 0
"ClickUp": {
"main": [
"node": "Slack",
"type": "main",
"index": 0
"IF": {
"main": [
"node": "ClickUp",
"type": "main",
"index": 0
"node": "NoOp",
"type": "main",
"index": 0
"NoOp": {
"main": [
"node": "IF1",
"type": "main",
"index": 0
"IF1": {
"main": [
"node": "ClickUp1",
"type": "main",
"index": 0
"ClickUp1": {
"main": [
"node": "Slack1",
"type": "main",
"index": 0
I am running a self-hosted install of version 0.95.1
