Error when copy object to using node s3
Hello everyone,
I encountered a hostname/IP mismatch error while trying to access the file2.txt on the Amazon S3 service (file2.txt.s3.us-east-1.amazonaws.com). The error message states that the hostname is not listed in the certificate’s alternative names, which include DNS entries such as s3.amazonaws.com, *.s3.amazonaws.com, s3.dualstack.us-east-1.amazonaws.com, and others.
I’m seeking assistance in understanding and resolving this error. How can I rectify the mismatch issue and access the desired file successfully? Has anyone encountered a similar problem before?
n8n Version: 0.181.2
Hi @leosantosx, I am sorry you’re having trouble.
I just gave this a quick go on my end using the current version of n8n. This is my file listing:
Copying also works as expected, provided I start the path with a slash /:
Perhaps you could adding the leading slash on your end and confirm if you’re still seeing this problem? If so, could you also give this a go with the current version of n8n?
